Improve Basic Skill Damage in Diablo 4 | U4GM Topaz Tips
Glico
Mensaje por Glico »
I wasted far too much gold making Flawless Topaz for gear I replaced two Torment sessions later. The tempting mistake is treating every socket as a permanent upgrade. Before spending on Diablo IV Items or crafting materials, check what your build actually does between cooldowns. Flawless Topaz is still a very practical Season 14 gem: weapons gain Basic Skill Damage, armor gains Intelligence, and jewelry gains Lightning Resistance. The right slot matters far more than simply filling every socket.
When Flawless Topaz is actually good
Weapon Topaz is strongest when your Basic Skill contributes real damage instead of serving only as a resource button. Heartseeker Rogue and Forceful Arrow setups feel the benefit immediately during fast Helltide clears. Some Spiritborn rotations also keep attacking often enough for it to matter. On the other hand, a build that casts a Basic Skill once every few seconds to refill resources will usually get more value from a different weapon gem.
Armor Topaz has a broader use during early and mid-Torment progression. Intelligence adds damage for Sorcerer and Necromancer setups while helping with resistance scaling. I also like it on temporary armor when a character is short on Intelligence for a Paragon threshold. It is not exciting, but it can solve two small problems at once without changing affixes or reworking the tree.
Three checks before you craft more
My usual rule is to inspect the full character sheet and the skill bar before touching the Jeweler. That saves more materials than blindly following a build screenshot.
1. Socket weapons first when Basic Skills clear packs, not merely generate resources.
2. Use armor Topaz to reach Intelligence needs before replacing strong existing defenses.
3. Keep jewelry Topaz for Lightning Resistance gaps, especially before difficult boss attempts.
Do not craft a full set for leveling gear unless you have a large material surplus. Gem drops accumulate quickly while farming Helltides, Nightmare Dungeons, and Infernal Hordes, but gold can disappear surprisingly fast once you are also rerolling affixes, tempering items, and upgrading equipment. One or two useful sockets on your main weapon and chest are usually enough while your loadout is still moving.
Topaz versus later Horadric choices
Flawless Topaz remains reliable through regular Torment content because its value is direct and predictable. Horadric gems become more attractive when your gear, aspects, and Paragon board are already settled and you are pushing high Pit tiers or refining a serious PVP setup. Their special effects can outperform a plain stat bonus, but only when the rest of the build supports them. Replacing every standard gem early often produces a smaller gain than fixing one weak defensive roll or improving resource sustain.
For practical farming, keep several Flawless Topaz ready rather than committing every copy immediately. Swap weapon Topaz in when your Basic Skill handles most of the route, and move toward specialized sockets when your late-game rotation no longer relies on it. Players comparing prices for Diablo IV Items for sale should still protect their gold for meaningful gear upgrades first, because a good item upgrade usually beats a minor socket adjustment.
